Recently I updated my Amp from a Sony STR-DE695 to the Denon AVR-591, after doing this I've taken a long hard look or listen rather to the weakness in my system.
Currently I'm using an Infinity SUB750 as the sub, 2x Technics SB-LV80 for the fronts, Infinity TSS750 Centre and surrounds.
I was using the TSS750's as the main L & R but they were entirely too weak when compared to the Technics.
The sound system is in a small living room dedicated as a "Media" room.
I am currently looking to upgrade the speakers, as I'm on a tight budget, it will have to be piece by piece, and my first consideration as mentioned above is the subwoofer.
Given the current setup, how much of an upgrade would the Boston Acoustics CSSUB10 be over the dated SUB750 from Infinity?
I am aware of how terrible the TSS750's are, financially I could do likely ~500 for the sub, but that's pushing it, if they BA CSSUB10 is that big of an upgrade the $299 price range is a much better fit.
What would my best upgrade path be to pull this system into something decent? If not sub first what order should I update? If I still go with the sub first, what next?
Sorry for the long post, hopefully someone won't mind helping me.
Thanks.
