Eric is completely wrong, and Scott is partially wrong. You have to balance the resistors. Matching a pair of resistors, in a series parallel configuration, with the impedance of the driver, does this. You can't use any resistor. You must use one that has a power rating equivalent to that of the speaker (series) and one that will take the shunt current (parallel). There are plenty of online calculators that can help you do this. I do not recommend a novice doing this; chances are they are going to make things worse than they were when they started.
