With that said, if you cut the resistance (ohms) in half you should double the wattage. But speakers and amplifiers aren't perfect. The resistance of a speaker will vary under operation as will an amplifier under load. Unfortunately with electronics some of the power required to run the item is wasted in heat production. (damn physics
) I can't wait till we get superconducting audio equipment. Liquid nitrogen cooling systems........
I'm no expert and I'm sure one of the "pros" around here will correct me. It's been over 20 years since I went through electronics tech school.
