The purpose of the Green Glue is NOT to act like a glue. Rather, it is an viscoelastic isolation layer that allows the 2 layers to act separately and turn some of the vibrations into heat while still allowing the mass to do it's job. It is a VERY effective isolator.
Now, for deep deep bass, there is an additional step that should be taken. That is the physical isolation of the walls of the room from the other rooms beside and above. To isolate from above, build the walls 1/2" short and use PAC International DC-04 clips. To isolate from the other rooms around, you can do things like
- a staggered stud wall so the inner and outer drywall for the 2 rooms do not share studs
- RSIC-1 clips to buffer some of the vibrations from transferring if you don't have room or can't redo walls, etc.
The other thing not to forget is the details like caulking EVERYTHING (outlet boxes, switches, between drywall joints, where wall plates meet the floor, etc. Door seals and solid core doors are also a must.
Think of the room as an aquarium. It doesn't matter where the leak is or how big it is - you're getting wet!
Bryan
