Question about connection via eARC
Jay72
I have a question, I'll preface with that I just purchased a Yamaha Rx-V485 and a Lg 65" Nanocell 90.
My question is let's say I had my android tv and ps5 hooked directly to the TV, then the tv to the receiver via the eARC. what would you set the receiver to as there would be nothing in any of the HDMI ports?
I'm not planning on having everything into the tv but the ps5 but when I would want to use it in have no clue how the receiver would handle that.
Thanks so much as I know it's a basic and possibly silly question.
The Audio is returned to the receiver via the HDMI cable between the TV and receiver as long as you use the eARC ports on both units. Both units must support eARC. The you select TV audio on the receiver.
Jay72
Ahh, thank you, looking through the remote and programs I can scroll through I don't see tv audio, but there is audio 1 I will give that a shot. There are also 4 "scene" buttons in the remote, one labelled TV I'll try that too. My tv doesn't come until Wednesday and my current tv doesn't have arc so I haven't been able to totally play with it.
