Quality of headphone output on laptop vs DAC
Revelation
Revelation
I have a Microsoft Laptop 4 which has an output jack on it. I play my Focal Clear MGs through it with Tidal, it sounds pretty good. I am wondering how different it would be if I used a AudioQuest Dragonfly Cobalt DAC from my PC through a USB compared to just using the headphone output jack on my PC?
MalVeauX
MalVeauX
Hi,
It will sound differently likely, for a few reasons. The headphone on your laptop is connected to the chassis, so any moving parts, fans, etc are all connected there and will share noise. Going to a USB DAC cleans that up. The other reason is not so much the DAC (since you could easily end up with he same DAC chipset or something similar quality actually) but actually the output amp stage that is used as depending on what they use, these can color sound or simply be better quality than whatever your laptop is using. So you would be looking at a USB DAC/AMP combination unit, or two separates (DAC and AMP). The other factor is the quality of the recordings you're listening to (and lossless doesn't matter, I'm referring to the actual recording being high quality and not just poor quality recording at a high bit rate in a lossless container). So if it sounds good now, it should sound cleaner, less noisy, and maybe just overall better if you get a dedicated system. But will it be night & day? Maybe not, depending on what it is right now (can't say without having heard it or seen measurements of your laptop's output).
Very best,
Eppie
Eppie
Laptop DACs and amps are not particularly good. OK for your average gaming headset. For something as nice as the Focals I think it's worth the investment. How different it will be is rather subjective but the Dragonfly Cobalt is not crazy expensive. Maybe have a look at Cheap Audio Man's DAC roundup from October but remember that you need one with a headphone amp.
