Well all sound replies, but I'm still not sure what to do. I mean, I know that different recordings are of different quality (compression and what not). I know that a good system will reveal poor masterings. None of this tells me how I should go about buying a given CD.
Now, I don't have some absolute reference level system that I may just pop in a CD and tell if it is good or not. Chances are, if I felt that the sound coming out was not up to scratch, I wouldn't be able to tell if the problem was the source or the AVR or the speaker (or well, the room). In fact, since I don't have an absolutely perfect setup and source to compare to, I might not even know if the sound coming out was as good as it got, or otherwise.
So what I'm saying, all things considered, is that I'd just like to get what is known to be a great mastering so that I may forget about the source part. Especially, as even a very good CD can be had for a lot less than very good speakers. Besides, your CD collection is something you'll keep (no need to upgrade
); so might as well get the best you can and only worry about your other components when you want to get better output. That sums it up.
I will visit the Hoffman forums (fora?) and look into the Acoustic catalog thing. Don't think I'll bother with Stereophool, oops.. where are my manners? Except when I want entertainment, or when I feel like reading poetry
. So what is this Acoustic catalog and how do I get my hands on it?
