Pyrod AV 1500 Receiver problems
G
grant67
Hi all
Have a Pyrod av 1500 surround receiver (UK built???) with no remote and user manual so I'm having trouble trying to change the speaker configuration from 5.1 to 2.0 as I want to only run 2 x speakers from this amp. Trying to use the functions on the actual amp only gets me so far not sure how to go any further. I push the mode button until it flashes bypass and above it also flashes edit but that is as far as I can get. The actual amp is setup in "centre mode wide" and all I want is for it to be setup as LS & RS? Can anyone help with a user manual or manually setting up the amp.
Thanks
Grant
WaynePflughaupt
WaynePflughaupt
The lack of responses tells me that no one else has heard of this brand either. I’d suggest contacting the manufacturer for a replacement remote, or try ebay.
Regards,
Wayne A. Pflughaupt
