Pyle PTA1400 Amp with Fast Track Pro
Keizer Soze 313
Keizer Soze 313
not sure if this is the right forum for this issue i'm having. any help is greatly appreciated!
ok, i like to DJ in my spare time. i have an audio interface, Fast Track Pro, that works just fine with my monitors, and home theater setup. every bit of software i use works just fine and the settings never need to change whether i'm using the monitors or home theater or any particular program for DJing.
recently bought an amp, Pyle PTA1400, to push these speakers (Pyle Pro PADH1279) i've never used. had a DJ friend of mine give me some insight on proper cables and what not and he showed me where to plug what into what.
i use two applications to DJ, Deckadance and Traktor. with both programs, the audio setup is the same and it works perfect without the amp. HOWEVER, when i use my new amp and speakers, Deckadance works and Traktor does not. nor does any other software i use...just Deckadance.
i don't get it, what am i doing wrong?!!
i'm attaching any and all images that may shed some light on my setup.
**UPDATE**
ok...so, yea...i feel stupid. after uploading these images and posting this thread, i noticed a setting in one of the images. needless to say...it's fixed now.
ANSWER: mix level in the software (which is odd cuz i thought that only pertained to the headphones...but, whateves!)
Keizer Soze 313
Keizer Soze 313
btw...another reason was the output needs to be on 1/2 instead of 3/4
