I have noticed a curious difference between Apogee and Magnepan speakers.
If one looks at the manual for the Apogee Stage speakers, which are a full range "ribbon" speaker (they are what Magnepan typically calls "quasi-ribbon"), one finds that toe-in is not recommended, and if it is done, it should be extremely slight:
http://www.apogeespeakers.com/manuals/stage_manual.pdf
In other words, Apogee recommended placing them basically parallel to the wall behind them in a normal room.
If one looks at the manual for a Magnepan speaker of similar design, one finds that they recommend that the speakers be toed-in. In other words, they recommend that the speakers not be placed parallel to the back wall, but aimed more at the listener. This is true of their new model MG 1.7, which is a pure "quasi-ribbon" speaker:
http://www.magnepan.com/content/binary/pdf_manuals/manual_17.pdf
The same recommendation is true of every other Magnepan speaker that I have checked.
Now, one might be tempted to think that one of them is just wrong in what they recommend, but I happen to own a pair of Apogee Stage speakers, and have a brother with a pair of Magnepan speakers, and I can say from personal experience that each manufacturer gives the right recommendation for their own product (as, of course, they should). So we now get to my question. Why is it that the one sounds better with significant toe-in, and the other sounds better without significant toe-in?
With most speakers that I have heard, they sound best aimed more or less at the listener, or in other words, toed-in, though obviously truly omnidirectional speakers would not be that way, and anything that has a very wide dispersion, one would normally think that toe-in would be generally irrelevant (as with an old pair of JBL L36 speakers I have, which subjectively appear to have an incredibly broad dispersion pattern). But in the case of the Apogee Stage speakers, they sound best
not toed-in.
I don't have the necessary equipment to test what is actually happening, so I am simply hoping to find someone who might know the answer, or at least have a plausible theory about this.
