Putting together a stereo system.
aks1
Hello, I'm trying to put together a stereo system for my mom for Christmas.
I'm still very new to this and this is what I came up with so far. Any advice is appreciated. Thanks.
Yamaha R-S202BL Stereo Receiver - https://www.amazon.com/Yamaha-R-S202BL-Stereo-Receiver/dp/B01EMQI2CU
Denon DRW-580 Double Cassette Deck - http://www.vintagecassette.com/denon/drw-580
Audio-Technica AT-LP120-USB Direct-Drive Turntable - https://www.amazon.com/dp/B002S1CJ2Q
ELAC B6 Debut Series 6.5" Bookshelf Speakers - https://www.amazon.com/dp/B014GSEQ06
shadyJ
Speaker of the House
Staff member
Looks like a fine system. You will need to use the turntable's internal preamp to use it, btw. so be sure to set that up correctly. I am assuming your mom has a tape collection, hence the cassette tape deck.
jmalecki05
She will have a very merry Christmas indeed :).
3db
3db
I would steer clear of cassette decks offering dual tape drives and stick with a single tape drive instead. More money will be put into better parts for a single drive unit than spilt across two drive units.
I found this for $50 used and it really works well.
