PureAV PF60 question
sanoel
I have just got a PF60 from Belkin. My house is old 1969 was when it was built. There is no ground wire running thru my house. The PF60 shows that there is no ground present. Can i still use the PF60 and it do what it is suppose to do??
Thanks
MDS
If the electrical wiring in your house isn't properly grounded you have serious problems that should be addressed by a qualified electrician immediately.
sjsmithjr
It is not uncommon for older homes to have two prong receptacles with no safety ground. Sometimes, the older two prong recptacles will have been replaced with three prong receptacles with the ground disconnected. Bottom line: a surge suppresor has to be properly grounded to work.
It is possible to properly ground the receptacles in your home, or even just the one you've got your AV equipment plugged into. Google 'two prong no ground' and you'll get several hits on how to do it. Even if you're not comfortable with tackling the job, at least you'll know what to ask a qualified electrician to do.
Good luck,
Sam
