I'd probably skip fixing this one and put the funds toward an upgrade. Sounds like the amp is failing on that one and info on the web doesn't turn much up on it. If you had a spare amp around, you could bypass the internal one, but if you have to buy an amp, I'd just replace it. What's the budget and room size?
