bryantm3 said:
why don't you just go with the plasma? i've never really seen better performance from a projector than from a straight television set, unless it's film like in the movie theatre. but i don't know, i'm not that knowledgable about televisions.
Have you actually seen a decent home theater setup to base that statement on? I mean, in a 100% dark environment, with a calibrated projector, and a decent screen? Plasma easily equals, if not bests, some of the best plasma displays on the market... Oh, and it's four times the size or more!
I would go with a plasma lift... Here's why.
Tab-tensioned projection screens are excellent, but they tend to use a black fabric for the surrounds instead of a black velvet. While this works well, it is nowhere near the same quality level that black velvet is.
On the flip side, when you put up a fixed screen, with a good black velvet border (think Carada, Criterion screen w/brilliant white surface) you get a near perfect film screen, then you can combine that with about any plasma in the world. The plasma just needs the lift, any plasma works with it, and it doesn't suffer in any way from being on the lift.
Add to that if there is any air circulation in the room that hits a drop down screen it may (not likely) cause the screen to sway a bit in the air currents which can cause uneven image appearance throughout a movie.
That's my take on it, and frankly, I've never heard that option before - I like it!
