PSB vs Axiom
Sheep said:
I would say go axiom.
The Tower, as mentioned above, will be easier to drive, and has the same FR as the Psb's. The Axiom center will probably have a wider dispersion then the Psb aswell. If you and considering the b15's for the rears, the QS4 and 8 would do a better job creating surround effects, and have a big dispersion then the PSB.
I would go axiom,
sheep
How can you recommend something on probably. That makes no sense to me at all.
They are both very good speaker systems and I've heard both. It all comes down to what you prefer in sound. The Axioms M60s lie on the brighter side of neutral, have a wide dispersion, and good tight bottom end. The PSB T55s are very revealing, but a lil on the mellow side of neutral . The bass is as deep and tight as the M60s. Midrange is equal on both But if imagiing and soundstage are important, then you can't beat the PSBs. Not for the money.
The center channels are quite close but I would give the nod to the Axioms as its a bigger speaker. To compare a dipole speaker with a monopole is like comapring apples and oranges. You need to compare the PSBs S10 ( I believe is the model #) to the QS4s of Axiom.
I own the smaller Image T45s and love em. I have a crappy little Technics receiver that has no problems driving them to insane volume levels.. They like T55s are 6 ohm speakers and are very innefficient.
Listen to both and make up your mind.Remember, you are listening to them with your ears no one elses
