PSB Stratus Subsonic 7 Spikes or Rubber?
porksoda
porksoda
Hiya,
Not sure if anyone here owns this beast.... what u guys recommend spikes or rubber for it.. i have it placed diagonally into a corner with the port facing the wall... hardwood floors and using rubber feet.
any suggestions?
Sheep
Sheep
rubber
If I think i know what your saying, use the rubber feet.
If its on hardwood floors, rubber.
If its on carpet, spikes.
Thats basically the guide to choosing a cabinet termination.(correct terminology?)
sheep
Never heard the phrase cabinet termination....makes me think of the speaker wire terminals.
Another option is to put a piece of foam/rubber or a piece of carpeting with rubber backing underneath (and you can do it far cheaper than the Auralex type pads). The purpose of the spikes or rubber feet or mat is to prevent the sub from "walking".
Rubber feet that you already have on it should be fine.
3db
3db
+1 for rubber. Spikes will just scratch the hardwood floor and do not offer a sonic advantage.
3db
3db
Agreed but why did this thread pop back out front again.. like an X files case reopened :D
