3db;
Excellent review, thanks for your input on the 45s. They have a similar build, seem as though they may be just a bit smaller in the soundstage dept. (possible compression you experienced?) due to the size of the enclosure and drivers when compared to the T55s and lack of additional drivers in comparison to the T65s, but do sound as though they may be a good value.
I am currently running (mostly) an Infinity Interlude setup (IL50 LR, IL36C, IL10 SRB & OWS SS) which with my other components sounds pretty respectable. Considering I was able to get all 7 for less than $1,100.00 (some of it used), it's a nice setup for the money.
Nevertheless, I've been exploring new speaker options as I believe I'm not quite satisfied from a musicality standpoint (although movies sound very good with this setup) and would like to see what else is out there in a slightly more expensive arena or even same price range. The PSBs look similar in build, but I believe may be a bit better in performance, but I haven't had the opportunity to listen to them as of yet. I've considered evaluating the larger Ascends as well, but again, have not had the opportunity to this point.
Thanks again for your feedback on this, sorry if I hijacked this thread a bit..
-TD
