PS3 output questions DAC questions
mibson
I have a ps3 I will use as a cd player.
My preamp only has RCA inputs.
1) Will my ps3 be the hardware that does DAC work(when using the RCA output cord from the PS3)?
2) If I get a preamp or receiver with optical and/or HDMI inputs, will my receiver now take over the DAC work?
Thanks for any help!
adwilk
adwilk
You got it...
The DAC in the PS3 will convert to analog when using its RCA outputs..
If you use any digital transport, the other end will do the work.
mibson
optical?
If I use optical cable, does the ps3 do the dac work?
