ps3: need setup help
chr0no831
I would like some help setting up my ps3 to get some 5.1 surround sounds.
my TV is a Philips 42PFL7422D/37.
It has these input/outputs:
AV 1 (1, 2, 3Fh autoranging), Audio L/R in, CVBS in, S-Video, YPbPr
AV 2 Audio L/R in, CVBS
AV 3 (1, 2, 3Fh autoranging), Audio L/R in, YPbPr
AV 4 HDMI, Audio L/R in
AV 5 HDMI
AV 6 HDMI
Front / Side connections Audio L/R in, CVBS in, Headphone out, S-video in, USB
Other connections Monitor out L/R (Cinch), S/PDIF in (coaxial), S/PDIF out (coaxial)
I have a home theatre system which is a Philips HTS3555/37.
HDMI output,
Component Video output,
S-Video out,
Composite video (CVBS) output,
Digital coaxial in,
AUX in, TV in (audio, cinch)
Thanks for your help
G
gus6464
AV 5 HDMI
AV 6 HDMI
HDMI output,
S-Video out,
Digital coaxial in,
I highly doubt that the HDMI on your HTIB supports MPCM. And it looks like you don't have toslink as well and I don't know if they sell any coaxial-> toslink cables or adapters. Sorry to say this but there is no way for you to get 5.1 unless you upgrade to a new receiver.
chr0no831
Thanks, you guys have been really helpful.
I was wondering if the Toslink To Optical Mini Adapter is what I need.
Also I was wondering if I could use the coaxial digital out from my TV to receiver.
G
gus6464
Toslink to optical mini is not the same thing as coaxial so that will not work. Also the coaxial out from your TV is a passthrough that works when you are getting and HDTV signal over a OTA antenna so you can get 5.1 through the receiver. Also PS3 only has toslink out so you need either a cable that has toslink on one end and coaxial on the other or a new receiver altogether with optical or hdmi which can handle MPCM.
chr0no831
Thanks for posting
Then i guess my only option is to use the Optical Toslink to Coaxial (RCA) Digital Audio Converter?
Semi Off topic: Anyone know if I would need to pay duty buying the Optical Toslink to Coaxial (RCA) Digital Audio Converter from the states?
