Hey guys, I'm really confused with this. Everything used to work fine now there's some new problems.
In the PS3 home menu, surround sound works perfectly. HD picture, everything good like it once was. When I load the game Metal Gear Solid 4... the surround sound turns off. I have no idea why. This occurs when the game is loading and the TV flickers and adjusts to the right HD settings (never understood why this varied from the menu screen).
I'm using an LG Model: HT963TA system, and used to use it perfectly with only the HDMI cable (no optical). I'm thinking it's the surround sound system that is the problem because when the game loads a small Dolby Digital tag appears on the display of the device... and it never used to be there. The manual is horrible and I can't find anything about this problem.
Really hope you guys have a clue.. this seems like such a bizarre problem. Thanks guys.
