Bryce_H
Bryce_H
2 Questions
1) Afterbuilding my dedicated HT I need to extend my controllers to the seating area from the equipment closet. I found the following options on Amazon. Anybody have any experience with any of these?
GEMINI ACCESS Recoil 10 ft. Multi-Platform Extension Cable (10') - $7.99
Monster Cable PSFP-7 FreePlay for Playstation 2 (7') - $21.83
HIP INTERACTIVE Extension Cable & Spool for PS2 (8') - $4.99
PS2 Controller Extension Cable - Intec (6') - $9.89
2) I also want to hook up my PS2 with component and optical
a) can I use any old optical cable?
b) I know there is a hatred toward Monster (I have it too), but is there any advantage over the basic sony component cables
Thanks.
jaxvon
jaxvon
1. Go for the length you need and don't pay the $21 for Monster.
2.a. If it's a standard optical cable, then yes. There's nothing magical about PS2.
b. Not from what I can see. Monsters look prettier, but they both use small, almost pathetic looking coaxes. If monster was big and beefy, I'd say yes, but in this case they both look quite tiny.
claudermilk
Monster is 3x as much as the rest for a shorter cable? That should be a no-brainer. I don't recall who made the extender I'm using (heck, don't even remember where I got them), just some generic brand & they are fine, I'd probably go with the chepest one.
As for the oprical, any decent one will do; I'm using a basic Radio Shack one with mine & it works fine.
Bryce_H
Bryce_H
Nice deal except shipping is $6 each with no combined shipping options!
Francious70
Francious70
Yes, but each package comes with 2 cords, so you only have to buy one.
Paul
G
geo75
I've used everything from the cheap to the Sony. No real difference in the extension cables for PS2. If your PS2 is in an open spot Pelican has also released some decent wireless controllers for around $25, not recommended if your PS2 isn't facing the seating area though. As for the Optical cable There's no real difference with the PS2. XBOX makes you buy theirs.
