Highly tweakable?
As in, you will have to tweak it into a completely different set if you want to view HD discs on it next year since they will all employ HDCP protection?
I think 3.5 stars out of 5 is a complete gift. That is a poorly engineered display device to lack many of the basic image handling capabilities that you do find in a quality display. Especially displays of far lower cost.
The lack of HDCP should completely negate this unit from going into the home of ANYONE! At that price, it isn't a maybe - it is a MUST - it MUST have HDCP to be of any value to someone.
I just don't understand:
Build Quality - 4 stars - yet the IR window doesn't allow for 'normal' remote usability? Is there something that makes it substantially BETTER than average in build that makes up for this? I mean, I would consider average to be 3 stars.
Also: Detail and video quality - 3.5 stars? For a display which doesn't recognize many film patterns and requires a high quality outboard video processor to produce the actual image since onboard processing is so poor?
I hope others realize that the 3.5 'overall' rating for this product really does equate closer to a D- score for this product which is clearly lacking in basic areas which almost every other display at that price range does reach.
A $3K computer monitor sounds more like what the review was of - not of a well designed television.
I don't think the review itself is in any way bad - it genuinely reflects these issues and it is what I referenced to draw my own conclusions as I hope others will. But, the star rating is what some go by... shame on them.
Keep up the good work guys.
