Protecting cables and speaker wire across doorway opening?
E
E-A-G-L-E-S
I have chnaged my set-up and now have all my gear in a nearby closet away from the display, front stage and sub.
I am going to use external raceways to hide thew wires along the floor(renter), but there is a bedroom doorway I must span with a 24AWG HDMI cable, a sub cable, and five sets of 14guage speaker wire. to get to the main rooms' walls.
What can I use to protect the cabling from an accidental tripping or pulling on?
*I'm a renter
*I already have the cabling and cannot, due to not being long enough, run it over the door and back down the other side....so it has to run across the floor.
E
E-A-G-L-E-S
bandphan...thanks so much for all your recent help!
Those look very promising but......that does not look like it would fit all my cables. Do they make larger or possibly I could run two or three next to each other in parrallel.
E
E-A-G-L-E-S
Ahh, you snap the cables in from underneath, not run the heads that are too big through.......duh.
Awesome bandphan!
dorokusai
dorokusai
Most of those will accomodate a standard power cord and a few pieces of CAT5....if that's a reference for you. Any larger and you almost defeat the purpose.
Mark
Polk Audio CS
bandphan
bandphan
yw, yep it should be fine
E
E-A-G-L-E-S
Mark
Polk Audio CS
Chinese, but it sounds like you have used them at one time for yourself, business or an install maybe and you didn't say anything negative....so I take that as a good sign :)
dorokusai
dorokusai
It's Japanese and I'm a Maryland based redneck....who'd a thunk it? ;) I agree, you'll be ok.
Mark
E
E-A-G-L-E-S
O.k., I need a little more help here.
All the references are for Cat 5 cables.
How do they compare in size to 14guage speaker wire, a 24guage HDMI and a thin subwoofer cable?
bandphan
bandphan
also they are designed for extension cords, you will be fine, just zip tie then for neatness, and less chance of movement
