Ric_Flair
I am looking for feedback on Pronto remotes. I have an NAD C740 receiver and a Denon DCM-370 5 disc CD changer. I was wondering if anyone has used a Pronto and if they have if the remote is compatible with NAD products. Any suggestions for other universal remotes?
rgriffin25
rgriffin25
Moderator
I have setup several pronto remotes at work for various customers. It will do everything you need and then some. However, I find it hard to use with the touch screen. It is very similar to a palm pilot so the use of a stylus is very helpful.
After using several of the pronto remotes I decided to buy a remote that I thought would be easier to use. For the price, I feel the Home Theater Master MX-500 is a great buy. It is just as easy to setup as the pronto and in my opinion is easier to operate.
Either of these remotes will operate any of the features for all of your equipment. So what ever you choose will be better than a pile of remotes on the coffee table.
www.hometheatermaster.com
Hope this helps,
