projector and screen layout
Jimmy
Hi there
I am looking at projectors
We have a room that is 4m by 5m
Also another that is 5m by 10m
I do not know where to situate the projector & screen
Is there a rule of thumb for distances for....
The projector, the viewing distance (min and max from screen?)
I don't want to get sore eyes
The projector would most likely be ceiling mounted
Each projector has a recommended throw distance depending upon the screen size you select. You want to sit about 1.5x the screen width away MINIMUM for DLP and 2x the screen width for LCD. Find your desired screen size and do the math using the provided calculators given on most manufacturers' websites.
BMXTRIX
BMXTRIX
The big room sounds awesome - but it really depends on how much time, effort, and money you want to invest into a home theater for the room you use.
Either room is of deecent size, but the 15x30 foot room (5mx10m) really sounds like it would be ideal.
As Clint says - the going rate is at least 1.5x screen width - though many would seriously argue the 2.0x width with the current generation of 720p LCD projectors. But, few will argue that if you have the budget, a nice DLP is the way to go... except for some LCoS lovers. ;)
There is some good information here, and some excellent information on www.projectorcentral.com that you can read about.
Without you having a specific budget set up yet (which is hard to do, I know) it is hard to say what any of your options are. But, in the big room, if you went with a 10 foot wide screen, you would put your first row of seats about 15 feet away, then a second and third row would be possible. You might want to consider a rear projection room with a long throw projector - this remove projector noise from the room and makes it feel more 'theater' like.
Other considerations in your budget should be:
1. Audio
2. Video Sources
3. Control of everything (don't have 5 remotes out in a nice theater!)
4. Room aesthetics.
5. Furniture
6. LIGHTING - One of the most often overlooked aspects of a nice theater is giving it good lighting with lots of loads and multiple zones.
Good luck!
XtremeAV
XtremeAV
There are really two aspects to consider.
1st is the throw rate that has already been commented on.
2cond would be light control, Alot of light (windows) is not a good thing to have when useing a projector.
Most manufacturers have helpful tools on there websites to help you calculate throw rate and screen size.
If you have a certain brand/model in mind then I can help you with the throw rate/screen size calculation.
Hope this helps.
Jimmy
:) Thanks for the quick response!
That is the info I was after
I am wiring in CBus for the lighting control
And will look around at projectors and screens
