Programming the Denon RC-969 Remote
F
Fred Brodeur
Hi everyone!
I bought a Silver 3805 and after a lot of problems with supply, I have a black 3805 "loaner".
I'm trying to program the RC-969 to turn on the receiver, cable box and TV with one system call macro. I've typed them up and programmed them but they don't work, something is wrong, I was wondering if some one could look at them and tell me where I went wrong, I'll make the corrections and post them here as payforward, so others can program their remotes as well
Here goes:
(Set preset codes)
Cable box
Off On
“1” (For “preset memory” )
“Cable” (Mode button for component you want to set)
“Enter”
0503 (“Preset Code” for Motorola)
“OK” flashes
Television
Off On
1 (For “preset memory” )
“TV” (Mode button for component you want to set)
“Enter”
1127 (“Preset Code” for Sony TV)
“OK” flashes
(Set up “System Call” Macro to turn everything ON)
Off On
3 (For system call settings)
Amp (Turn on the Amp)
Enter
Source On
Cable (Turn on the cable box)
Source On
TV (Turn on the TV)
Source on
Enter
“Call” 1
OK Flashes
(Set up “System Call” Macro to turn everything OFF)
Off On
TV (Turn off the TV)
Enter
Source Off
Cable (Turn off the cable box)
Source Off
Amp (Turn off the Amp)
Source off
Enter
“Call” 2
OK Flashes
My problem may be with selecting Amp in the "turn it all on" section.
With everything off, do I have to press "On" first on the remote THEN run the macro? or can I just click system call then 1 to turn it ALL on?
Gonna go wire the rear speaker...
Thanks in advance
Fred
mtamaku
Hi:
I have a similar remote for DENON RC-969. Where do you find the preset codes for other devices. I have JVC HDILA 61z886 and Samsung 850 dvd player. Any help is appreciated.
