Programming my URC MX 650
newb
newb
I know some of you have URC remotes. I'm wondering if you have any codes already figured out for the following products, and if so, how much will they set up automatically and which functions will I have to program (other than macros that is)?:
Pioneer 1150
Yamaha 663 (RCVR)
Phillips DVP 5960/37 (DVD)
Motorola DCT 3412 I (cable box)
Thanks for the replies...
bandphan
bandphan
all of the gear accept the 663 are in URC database and you can use the 659/661. Pioneer also has .mxf files on their website
newb
newb
Logging into the database
Is there a special method to getting into the database online, or is the manual the most up to date codes? I have heard (not 100% certain) that only installers can log into a database on the site.
bandphan
bandphan
My appologies, I thought you had the 850 not 650. You will have to program some of the newer features by learning. The majority of the base functions will be in the pre-programed codes.
jcPanny
jcPanny
URC Programming
I have one of the low end URC remotes and I had best results manually creating the menus and learning most of the commands from my other remotes. This way you have convenient access to all the functions you need. It takes a little time to setup, but it is worth it.
