Hi,
I use a very old Avermedia TV 203 capture card to capture the image from my PVR and games consoles so that I can play them over my HT. The problem is that it has utterly crap quality. I use Dscaler for the deinterlacing but whenever I use composite or s video for capture I have problems. I ahve never actually used the analogue TV part, just the video capture.
With composite the picture looks no where near as good as on my CRT tv and with s video, I get like a diagonal 'grid' of lines all over the picture that are clearly visible unless you sit about 10'/3m away. When I use my N64 or Gamecube especially, even when I use the dedicated 'old game' setting in Dscaler for the N64 which uses a half progressive picture sort of thing, it looks especially bad as the image flickers constantly.
I would like to be able to fix this problem as it is annoying having a great LCR speaker configuration on my PC for gaming but I have to play on mono for my consoles over my 18" CRT.
One problem I think is the capture card, which is from 1999 and I got for £10 as a clearance item, only supports output resolutions up to 1024 x 768 and I am running at 1680 x 1050.
I might get this capture card that supports up to 1080i capture and as so resolution as its a DVB-S card and can receive HD channels. I think that as its pretty recent it might improve the problem.
http://www.scan.co.uk/Products/Compro-VideoMate-S350-Digital-Satellite-TV-Analog-Tuner-plus-Video-Audio-Capture-Card
Specs:
http://www.comprousa.com/en/product/s350/s350-Specifications.html
Any Ideas?
