I have a problem with a passive optical switcher. Would love to hear if anyone has an idea how to correct it.
Im using a Rotel 966 with 2 toslink connectors, unfortunately I have 3 toslink devices (X-box, G5 Apple and Digital TV.) These devices only have Toslink, no coaxial option.
My problem is only the X-box will work, using the optical switcher. The switcher is connected to the Rotel with 1 meter Toslink cable. The digital decoder had another 1 meter cable.
I checked and switched all the cables. None of the cables are defective.
The G5 works with a long run (ca. 10 meter) straight into the Rotel, but as soon as i run it through the optical switcher.....no sound. I thought well maybe the run is too long. I hooked up my digital tv decoder to the optical switcher with 1 meter of cable. Same thing silence!
The receiver recognizes a digital signal is there, but there is no sound, no clicking, etc.... nothing.
I contacted the manufacturer of the Humax digital TV decoder, and they said their official response was......"The decoder software does not support an optical switcher."
I wont waste my time calling Apple.
I have tried all of the ports on the optical switcher and they all work with the X-box., but none work with the digital tv decoder or my G5.
Any ideas? Anyone experience this problem? I'm going to try putting an amplifier in the signal path, but theoretically I shouldnt need one.
PS. I liked the serious discussion on speaker cables. I've worked for 20 years in post-production. You can't make an original recording better than it is, you can only try to reproduce it as accurately as it was recorded. To acheive this you dont need exotic cables. If you like a pretty cable, thats cool, but I hide mine.
