Problems setting speaker calibration on Onkyo TX-SR602
AJD
AJD
Hello, I have an Onkyo TX-SR602 and my non-powered sub recently died. I bought a new Pioneer powered sub, hoooked it up to the sub output and then plugged in the automatic mic setup feature that I have used for years. After cycling the test tone 2x through and recognizing each speaker, including the powered sub, all seems fine. However when I go to listen to anything, the settings have overweighted everything to the front right speaker a small 3.5 inch old Cambridge Soundworks cube. I double checked all settings many times and even swapped out the speaker.
Based on inputs here I worked on manually configuring the settings and I feel like I am close, though the fronts still seem tinny. Much prefer to use the auto set up as I have had success with it in the past. Any ideas on why the auto set up is not working properly?
thanks!
