Receiver problem
Check the speaker wire connections at the back of the receiver and at the speakers. If you still don't have sound, swap the Left and right speakers. If it is not a wiring or speaker problem, then you will need to send the amp in for repair. If it is out of warranty, you might consider opening the cover and looking for a bad solder joint.
