problem with my quatro15
marrypoppins
Hey guys I have a problem, I just moved houses and now when I plug in my quatro it makes a hummm and nothing else, what is the problem how can I fix it.
T2T
T2T
Maybe, your amp is bad - or, there is just a bad connection somewhere. Check the cable from your receiver to your sub. Also, check to ensure the power plug is properly connected with a tight fit into the plate amp. If neither of these things are issues, then the amp itself could be dying. Possibly, the amp was dropped? Bumped?
marrypoppins
FIXED IT, ok I called ************ and they told me that I had a ground loop, so all I had to do was buy a plug converter and the whole problem went away.
Sheep
Sheep
Glad to hear it.
SheepStar
