Thanks for the info.
I have checked the connections and one of the speaker wires was a little "frayed" so I have fixed it and all the others look good.
I am not sure how you would check if the driver is shorted on one of the speakers as you suggested. I have noticed that when I do a testtone of the speakers, my subwoofer does not put out the amount of sound like it used to, and I have it turned all the way up to 10db.
It does not seem to have a specific time when it shuts down, just random times. As far as time to shut down, not real sure, but it seems like it will shut down 10 to 15 minutes after starting a movie and then just whenever.
