Modulation would not cause high def to be converted from analog to digital. An analog signal is just that...analog.. You show me true high definition thru a cable television coaxial ? It will not happen.
Now, taking a digital signal and converting it into a picture is another story..i.e. high def satellite..It is converted from signal to pic in high def, never being an analog signal. I know this is an audio forum, but for all you audio buffs...I know your monitor is also somewhere in the mix..If you are running cable television (any format) your wrong. You are missing so much...
