Hey all,
Been dealing with this problem and am a bit stumped for answers, hoping someone here can make a suggestion for me. Here's the story:
I recently put together a new desktop computer and installed a Creative Sound Blaster Audigy SE card. I then connected the the line in from my Sony STR-DE 197 receiver to the sound card into line in port (green).The receiver is then connected to two Cerwin Vega At-15's.
Here's the problem... After installing all of the drivers and getting the sound working, I found that when turning the receiver volume up past anywhere near half, I get a humming/buzzing noise with or without any actual audio output. I have tried messing with the computer and device volumes to find a configuration without the hum... to no avail. I then tried plugging into the onboard sound and found the same problem.
The strange thing is, I have been using this speaker/receiver setup for quite some time on my PowerBook G4 laptop (plugged directly into the headphone jack) and can turn the receiver up all of the way and get virtually no feedback.
My next step was to try using an external sound card to eliminate the buzzing on the desktop, figuring maybe there was some sort of interference caused by the proximity of the processor to the audio port and the analog signal (could this even be a problem?). I plugged my USB M-Audio Sonica Theater 7.1 sound card into the desktop and connected the receiver... same exact problem. Just to see, I then tried connecting the external sound card to the PowerBook and again found NO interference.
So it seems that the Sonica external card is clearly not the issue since it functions on the laptop. Since the built in, external, and sound blaster cards ALL get this feedback problem on the desktop, it seems like there must be some sort of problem of interference from the computer itself. Anyone had this issue or know how to solve it? Thanks!
*By the way... sorry if this was posted in the wrong part of the forum
