problem with avs2000
petty77
I am having problems with mmy signature avs2000. All I am getting is a humming noise. It was working fine one minute and the next stopped. Can annyone help me
thanks
mike
thanks
mike
We need to know a bit more about this. Does the unit hum when just plugged into the AC and not anything else, or only when connected to your receiver?
If it hums when only plugged in to AC then the power supply has failed in the amp and it needs to be replaced.
We have had a lot of sub failures lately from a number of manufacturers including AVS.
If it only hums when connected to your receiver, then you likely have a ground loop.
markw
I think he's talking about a Monstor* brand power stabilizer.
*I know...
jvgillow
Try completely disconnecting it from AC power, wait about 10 min, then reconnect it and see if it still doesn't work. If not, and you are still in the warranty period, call Monster support. If the warranty is expired, you can try removing the case cover and see if all the fuses are intact.
