Probably the best setup you've ever seen.
Wafflesomd
Wafflesomd
But seriously, it's just like this until I get my new desk.
croseiv
croseiv
Probably not, but certainly a decent set up. Your title certainly got me looking...;)
Sheep
Sheep
Are those the 2030A's? I'm picking up my MR5's this week.
SheepStar
Wafflesomd
Wafflesomd
SheepStar
2030p's. I suggest you get the 2030's instead.
I purchased them awhile back. Told wmax about them. He purchased a pair and measured them. The results were great.
WmAx
WmAx
Let's move it up a notch...
If the qualification is the most accurate/linear hi-fidelity system on a computer( easily exceeding most monitor systems found in most studios), I would wager mine is a contender. Accurate, +/- 0.7dB up to 16kHz, virtually zero resonance in either the drivers(text book perfect waterfall) or the cabinets(cabinets have double nested layers with very thick dampening core layers, in addition to a solid oak matrix bracing system every 2-3" on every axis internally). Drivers operate only in their pistonic bands, and power to this system is provided by XLS202D Crown amps on the tweeters(200 x 2), another XLS202D on the mids(200 x 2) and an EP2500 on the woofers(650 x 2), with 2 x 20A dedicated circuits to power the computer and it's sound system. Many broad band acoustic treatments cover this area, some of which can be seen on the left side wall and the back wall and ceiling in this picture. While not easy to see in the picture, there are two suspension systems. One is below the woofer modules, reducing vibration to the floor. The other is located in the connection platforms between the mid-treble modules and woofer modules, to prevent the mid-range from vibrating the woofer modules. Crossover system is via a digital active system, model DCX2496.
There is NO signature or sound to describe. It is simply a transparent window into playback of audio files. This system easily exceeds even the clarity/detail heard in most high quality headphones, except this is a speaker system, and provides a much better stereo sound field as compared to headphones.
Despite this, my main system is still far more enjoyable. This computer monitor system is simply a monopolar near-field system, which has limited potential in creating the illusion of a realistic concert hall or similar large acoustic environment(which is why I use omnipolar type speakers in an especially treated room for my main system).
-Chris
jamie2112
Well 1 of the systems on here is one of the best I have ever seen but regretfully it isn't yours Waffle.:eek: Chris's computer system smokes most hi end music setups and its just his comp system.....too much....although Waffle I like your style....:D
mike c
mike c
what's your amplification waffle? (or tell us more about the equipment)
Mika75
Mika75
Thanks for this post Wafflesomd, I've always wanted to know what Chris's room actually looked like ... :eek:
Djizasse
Djizasse
Chris, get your own thread! :D
Please?
Wafflesomd, can you show us the track?
Sheep
Sheep
He told me about them way back when. I was really impressed with the Mackies though.
SheepStar
Shock
Shock
It kind of looks like an A-Bomb blew up in that room.
An Audio bomb.
Wafflesomd
Wafflesomd
Here's the track:
http://www.mediafire.com/?njyytmzmztj
Here's my signal chain. Emu 1212m -> DCX2496 -> EP2500 - > 2030p's.
I can't wait to order a new desk already.
That TV is a 37" Vizio my friend just purchased for $550. I know it's a cheap wal-mart house brand, but the thing looks damn good. I mean really good.
We put the 37" on my desk, and we have three pairs of 2030p's setup in surround (sort of). Plus an x1 sitting in the back of the room.
These are x1's. 18" bandpass, 30-80hrtz.
It sounds pretty awesome in here. There are times when you want to set everything up properly. Take measurements and do other tests. Then there are times when you say '**** it'.
And if you would like, give this a listen. I made an attempt at dnb. http://www.mediafire.com/?golymenjyzg
Djizasse
Djizasse
So, the EP2500 is at 1/10th of full power and the DCX with -15dbs of attenuation on the LR inputs? :D That's the only safe way I could use a pair of Tannoys Reveal 6 with the EP2500.
