Why is it that with all the work trying to make higher quality connections between sources, processors, and outputs usage of existing 'pro audio/video' connections, etc. has not become a lot more common?
I understand that digital is making the actual signal connections less important to some degree, but lossless digital still will loose quality (although I use digital connections for 90% of what I listen to). Digital at 40-50khz (depending on the source) gives you 2 samples per cycle at 20khz. At 20hz you have 2000 samples per cycle.
Again, I know most people don't hear things outside of the range of 20-20,000hz but I still have not seen definitive proof that sounds above 20khz (or hey, even 100khz) doesn't affect the sound quality.
An extreme example: what about those ultra directional speakers they have been developing for years now where they use ultrasonic sound waves to restrict if you can hear the sound by not only direction but also distance from the speaker. (it has been over a year since I last saw something about these so I may be wrong on those details....)
