I am using a Pioneer SC65 as a pre pro with a Rotel RMB 1095 amp and B&W 804D speakers. I listen to music 75% of the time. I am thinking of upgrading my Pioneer and am considering The Rotel 1572, Marantz 8801 or 7701, and Yamaha 5000. Anyone have experience with any of these? Would all of these be superior to the Pioneer? Any other models I should consider?
Hi there, just to share my past experience, my setup is almost the same as yours. I'm using B&W 7 S-series speakers, driven by Rotel 1095. I switched quite a few AVRs before settling down with a Marantz processor (AV8003). After comparing side-by-side, though AV8003 doesn't have the latest audyssey, I observed a marked improvement in movies in terms of steering effects and multi channel integration. For music, musicality was a notch up too with the Marantz. [hence i kept this setup
Considering you are into 75% music,
1) If you are not intending to add stereo amp, AV8801 is a good choice. But first, you have to discern what is the Marantz house sound and whether you like it. It is a little different from the more dynamic sound signature from pioneer and onkyo amps, and this pro is a little pricey compared to option 2.
2) IMO, if u are really into music, suggest you keep your sc65, and add a stereo amp with HT bypass. e.g. MF, Parasound. For music, a stereo class A/B amp may be a better choice than a class D. I'm not into music, so those with stereo amp w/ HT bypass, pls jump in.
