If I understand correctly, you want to use a Denon AVR as a source and the Parasound Halo A21 as an amp for your front L and R speakers. There's no point in using balanced inputs if you aren't going balanced end-to-end through the chain. Even then, the benefit would only be in enabling a longer run. So, TLDR, just use the unbalanced RCAs.
