Most mid priced receivers will serve as a pre/pro better (ie better processing, video switching, etc) than dedicated pre/pros costing upwards of $3k. You may look into using a $1500 receiver as a pre/pro and buying an external 2 or 5 channel amp for the other channels (if the extra power is really needed) while using the receivers internal amps to power the back channels and distributed audio.
