Pre/Pro to Amp connection
DT1009
Any suggestions for a good set of cables to connect my pre/pro to my amp? I don't want to break the bank and wonder if there is somethng out there a lot of people are using.
majorloser
majorloser
Moderator
Plenty of good sources
If your amp and pre/pro can use "balanced" XLR connections, that's the way to go. There are many good on-line companies that offer good prices on interconnect cables. I'll list a few, including companies for video cables.
http://www.bluejeanscable.com/
http://www.monoprice.com/home/?CartID=&style=
http://www.westlake-electronic.com/
http://www.mycablemart.com/
http://www.cablestogo.com/index.asp?
http://www.impactacoustics.com/index_flash.asp?engine=ahjune
http://www2.dvigear.com/
The Audioholics recommended site:
http://www.audioholics.com/buying-guides/recommended-stores-manufacturers/recommended-online-companies/cables-interconnects
DT1009
Pre/Pro connector to amp
Thank you for taking time to reply and for all of the resources.
highfihoney
highfihoney
Majorlooser is right,the links he gave are of quality cables that dont cost a ton,if you dont like waiting on shipping you can go to any pro audio store,dj supply or guitar center & pick up what you need cheaply,way cheaper than messing around with Best Buy or Circuit City.
Peavey makes a fine cable.
