Pre-outs on Yamaha RX-V661
senna1a
senna1a
Does the Yamaha RX-V661 have pre-outs? I cannot find it in the specs, but wanted to be sure before I moved on to look at other AVRs.
Thanks!
Mike
mike c
mike c
yes they do. all you need to do is open the rear view picture and find the appropriate feature you need.
Seth=L
Seth=L
That is what makes the RX-V600 series such a great value, inexpensive, good features, and preouts.:D
darien87
darien87
Thanks!
Mike
Indeed it does!!! I use mine to feed an Acurus 200x3.
N
Nick250
Thanks!
Mike
Mike, Google is your friend. I took the title of your thread
Pre-outs on Yamaha RX-V661, stuck it on Google and the very first hit was this. Good luck with your purchase, it looks to be a very nice receiver based on their review.
Nick
Yamaha RX-V661 Reviews. AV receivers Reviews by CNET.
CNET's comprehensive Yamaha RX-V661 coverage: unbiased reviews, ... those looking to use an external preamplifier, the RX-V661 is equipped with 7.1 preouts. ...
reviews.cnet.com/av-receivers/yamaha-rx-v661/4505-6466_7-32378947.html - 87k - Jun 23, 2007 - Cached - Similar pages.
senna1a
senna1a
Thanks!
Thanks to all for your reply's.... It's down to either this amp or the HK AVR247.
