Pre-amp to amp interconnects
roidefromage
roidefromage
Hello,
I am taking the leap from an AV receiver to separates. I bought an Emotiva MMC-1 LPA-1pre-amp/amp combo, and am wondering of anyone could suggest the best cables (afforadable ones) to use between the two?
Thanks,
avaserfi
avaserfi
Any old RCA cable should work (you know those yellow/red/white ones) if you want/need to buy new ones check out monoprice.com
darien87
darien87
Yep. When I bought my 3 channel Acurus, Monoprice recommended just using component video cables, which I did. Works just fine.
