Hmm...
Try plugging the amp and the sub from the same circuit or wall plate.
If no avail, try some mix and match between your components, using the same or different circuits (wall plates).
Also, distance the amp & pre/pro from the TV, tuner (receiver) and cable box.
As long that the hum is not too loud, it's perfectly normal, don't fret it.
Bob
