Powered center or not?
hawk14
Hi all,
I'm looking to match a center channel to my PM 700s. I've looked into the clr 2300 and 2500, but given that I have a 15" def tech sub, is a powereed center necessary? The 2000 and 2002 are appealing but the 2000 is huge.
Thanks in advance for your comments. FYI, I have a five channel setup and with BPX's in the rear and an old Polk center.
Maximan
Ill tell you what,I just hooked up my CLR 2300 and all I can say is WOW!!!
Does it make a difference...HUGE!!
I had a Pro Cinema 1000 and this just blows it away.Dont hesitate,this to me is an upgrade worth having.
Now stop what youre doing and go get that speaker!!:D
hawk14
To Power or Not to Power the Center
Thanks for that Max. I guess I have no choice than to go with the powered, huh? :) The 2300 it is!!
7
7justwin7
Yes if you have room. I have a like new CLR 2500 for sale that I have never used because I have my Mitsubshi 46 LCD sitting on a corner stand with no place to put the center channel. So the speaker went right back in the box and has never been used. You may e-mail me if you are interested.
chadnliz
Boy 7justwin7 stepped in to sell before he is even a member, could be a con so watch out, all I can say is....... Beware!
