Wow lots of replies and thanks for the input and feedback!
My listening space is a converted 3'rd car portion of a 3 car garage, which was originally built as a recording studio (room within a room, specific dimensions, acoustic panels, etc.).
I have the Sierras on stands on the short wall in the front and positioning is about 8 feet apart and toed in slightly. The ports are pointed at a space of open wall between corner bass traps and a broadband panel. I find they sound better vs. ports pointed toward panels.
I've tried the sub behind my listening position and in various spots at the front of the room. What sounds best is about 4 feet directly to my left. I'm crossing it over at 80 and the gain isn't too high. I'm still playing with the various adjustments, so this may be the issue in the short term.
Don't get me wrong, the Sierras sound fantastic, with lots of detail and the sub adds to the low end. But as I've heard different systems, it always seems to me that those with higher powered and/or better quality amps seems to have a bit more "something" even at low volumes. In my OP, I called it "punch" but maybe "presence" is a better word.
So in thinking of more power I started running across posts / opinions on pro amps.
For now, it may be best to focus on my sub placement / tuning to see if I can get what I'd like to hear, particularly at lower volumes.
I may well see if I can talk someone with a better amp into bringing it by to see if it would make a difference. I know opinions are mixed on the difference between electronics, but a real-time trial might be most revealing in this case.
