Hello,
I wanted to ask one fundamental question about the output per channel from a receiver to the power that each individual speaker can handle. For example, for 7.1 system, the receiver is able to output 80W into an 8-ohm load. Now for the speaker description:
Center Channel: 20-125 W with an 8-ohm impedance
Front speakers: 20-100 W with an 8-ohm impedance
Surround speakers: 20-100 W with an 8-ohm impedance
I'm not using the rear back speakers, in other words, currently content with 5.1 setup.
My question is will the 80 W output from the receiver will be able to drive the speakers with the above numbers. I heard or am confused by the fact that if the total receiver output (80x7), 560 W is less than the total combined speaker power rating (the max, 125 + 100x4), 525 W + if I add the back speakers say, 50W each, in which case total speaker power rating will 625 W; will damage the receiver because its output power is less than the total power rating of the speaker (based on this confusion, I'm okay because my total speaker power rating would be 525 W as calculated above.), or in other words would I be undermining my receiver if I add the extra rear speakers (say 50W each).
All answers/responses are appreciated. Thank you.
