L
larry7995
I am thinking about having an electrician put in another plug on a new breaker for subs. Has anyone out there run into a situation where their HT equipment overpowers the breaker for the plugs in a room? Mine isn't now and I am ordering one of those kill-a-watt jobbers to see how close to using up my 15 amps that I currently (no pun intended) have available but I am curious if anyone else has dealt with this already?
L
larry7995
no I have a kill-a-watt on order and I will plug it in between the wall and the equipment, crank everything up to a powerful level and see what its showing, its supposed to be delivered on the 29th. I just wondered if anyone else had exceeded 15 amps with their total equipment draw?
bandphan
bandphan
To arrive at the amps, divide the watts by the voltage, which is usually 120 volts. I would stay at 25% from the total
L
larry7995
right so for instance if you had a 1000 watt sub that would be a max of 8.3 amps. I don't suppose realistically that the draw is anywhere near that much. If I had 4 MFW-15s running pretty hard I think that would probably pull about 8amps 350-120v=2.9amps so I figure each would draw 2amps
bandphan
bandphan
my velodyne recommends 10amps, its a 1250w amp, also remember consumption and output are 2 different things. Check your manuals for cunsumpation then do the calculations, im upgrading my house in the fall, adding a dedicated media room, and going to run a seperate service for that room addition, most likley a sixty amp service withvoltage regulation and one hundred fifty amp service for the rest of the home.
rnatalli
It would take a hell of a sub to drain an entire circuit. But if a large sub and amp were plugged into the same circuit, then you'd probably trip something.
L
larry7995
next weekend I will have the kill-a-watt and post some results
AVRat
AVRat
All my gear is on the same 15 amp circuit and have yet to pop the breaker even at very loud volume.
croseiv
croseiv
When I power my system up, I can see the lights flicker and dim a little. No breakers have been tripped yet.
E
Exit
All my equipment is connected to one socket and I haven't had any circuit breaker problems. I haven't really cranked it up though. The subwoofer is 900 W and the receiver is 120 W times 7 channels.
highfihoney
highfihoney
I used to pop breakers with my gear in stand by mode :D
I went with seperate 20 amp lines for everything,4 lines feeding the amplifiers & 1 line feeding the asociated gear.
L
larry7995
I'd love to hear that macintosh system
I got my kill-a-watt today and all my stuff together pulls around 5 amps with 6 amp peaks if I am really driving hard
trnqk7
Sounds about right to be honest. I have my stuff plugged into a ups/voltage regulator that has a watt reading (it's not instaneous, so not terribly accurate) and the max it has ever read is about 400W while watching a dvd (so 50" tv, dvd, receiver)...and it was loud enough ;) The sub is plugged into a different outlet though. On the other hand, my lights dim as well when I power the system on, but just for a second.
