Power Conditioner/ Surge Protectors
K
KrisJ
I was looking at a couple of units and am not sure as what benifit one has over the other, or if the benifits warrant the cost
APC 1.5 AV
Belkin PF60
Panamax EX 5500
jcrobso
This can be a can of worms.
I use a good surge protector($20~40) and then a battery backup UPS($80~100).
There is a lot of FUD out there. So much in fact that I did some research on the subject.
I'm a engineer at Chicago FM radio station, we are on the 10th floor of a downtown office building. I went to the shop turned on the oscilloscope and scoped the AC line. What did I see you ask??? I saw a nice and CLEAN 120VAC 60hz sine wave, I then pluged a B&D saber saw into the SAME outlet and TURNED it ON!!!! While watching the scope I saw NOTHING but the same 60hz sine wave. The floor below is the main computer room for a large corp. it is full of computers and the like. Now if your next door neighbor is a big factory you might have some interference.
Surge protection, YES! Battery backup if you have HDTV with a lamp, If you lose all power when the set is on the cooling fan will stop and the residual heat in the lamp can melt it! I have seen this happen. John
